- Joined
- Jan 17, 2016
- Posts
- 14,076
- Reaction score
- 24,429
- Ram Year
- 14 Sport
- Engine
- 5.7
Silicone lube or synthetic grease,don't use a normal petroleum based greaseI looked at my truck and see vertical seals as well. They are on the edges of the bed. My 2004 does not have them. I can see to the ground between the cab and bed. But...I have had an intermittent squeak which I thought was coming from the back seat area. Or because I put a camper shell on. Usually when moist outside. Could not find anything even with someone sitting in the back. Did not know about these seals and I'll bet that is my noise. By lube are you thinking a common grease?
