Ok, here is the one I used.
Lund 27121204 Black Bull Bar with Integrated LED Light Bar:
http://www.amazon.com/gp/product/B00WA4BGS4?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s01
Added bonus with this bar, it can retain the OEM tow hooks if you have added them to your express or sport AND you don't have to relocate the front license plate if your state requires one.
I am ordering a 19" x 1" custom yellow film tint from Lamin-X to match the light bar to my fog lights. I haven't wired in the light yet as I am trying to find the best way to wire them in with the high beams, but also have a cut off switch in case I don't want the light bar on.
Install takes some time, I would say the hardest part is removing and re-installing the lower black plastic splash guard after you have cut the 1" x 8" holes in it to accomodate the mouting brackets (instruction say 1" x 4" but the longer hole gives you better clearance to reinstall). Cutting is pretty easy and its on the bottom of the truck so if you mess up it is not something you have to look at daily.
One other modification to the Lund install instructions, the rear tow hook brace says to install it to the inside of the bracket, but with the tow hooks installed it will interfere with the bull bar bracket itself as both will be sharing a lower hole. I moved this bracket to the outside and the bull bar bracket to the inside and all fit well.
I was running out of day light so if you want more pictures of the install I can take them tomorrow, but it's pretty straight forward.
