TylerFT
A few months ago I got a 2010 Ram 1500 TRX4. It has the quad headlights but the light they provide is pretty minimal for backwoods Michigan. I don't want to get into the expenses of upgraded the housing so I'd prefer sticking with the stock quad headlight assembly. My biggest question is, considering cost, brightness and reliability, are LED's or HID's better? What will I need to install these lights so that everything plays nicely with the truck?
I have read a lot about needing CAN bus lights either way but it seems to vary a lot based upon the year of the truck so I decided to just make a new thread. I'm fully comfortable getting individual ballasts and connectors or whatever is needed if I can save some money here and there. I just need to know what kind of light setup to do and what components are needed to do it.
Also, I'd like to switch out the other lights for LED lights. I see the plate lights are 194 bulbs which I assume can be switched to LED bulbs without worrying about CAN bus. I'd like to also switch out the turn signals and brake lights. Will a LED flasher module take care of hyper flash? Is there anything other than just the new bulbs that I need? What bulbs do I need for the reverse lights as well as the map lights and dome light?
Any input is appreciated. Thanks.
