ac compressor
  1. A
    AC Compressor won’t turn on
    Hey all, Thought I would turn to the experts on some major trouble I’ve run into while recharging my A/C! I am finally recharging my AC after doing cam/lifters over the winter. Everything was going well until I was attempting to add the Freon when I could not get the compressor to turn on. I...
  2. M
    AC intermittent issue
    I’m having some trouble identifying the cause of my intermittent AC issues. I have a 2018 1500 Big Horn and I’ve been driving it about 100 miles a day and as the weather warmed up I’ve been turning on the AC. It was working fine for the first few weeks and started to now blow very cold for the...
  3. A
    Air Condition Issue- Works Intermittently - 2003 Dodge Ram 1500 SLT
    Hi folks, I'm the owner of a 2003 Dodge Ram 1500 SLT and I'm having some issues with the air conditioning. Specifically, the air conditioning does work while I'm driving, but when I'm idling, it doesn't blow cold air. This issue started a few months ago, but now that it's summer time - it's...
  4. Ryan J
    New ac conpressor or remanufactured?
    Im going to buy a new ac compressor but im debating on if i should by a new one or remanufactured one. New is $350 with $10 core fee, remanufactured is $220 with $ 70 core fee. Just curious if anybody has ever bought the remanufactured and had trouble with it or have they always worked?
  5. cmm47172
    AC clutch is not turning on
    I have a 2008 Dodge RAM 1500 with a 3.7L V6. My AC clutch is not turning on. I suspect either the low pressure switch or the high pressure switch. How can I bypass them as a test to see if the clutch turns on?
  6. D
    R152a refrigerant swap
    Hi folks.. I am replacing the A/C components on my 2007 2500. I am considering replacing the R134a refrigerant with what I believe is a more eco-friendly R152a refrigerant. Has anyone done this before and what did you learn? Thanks..
  7. H
    AIR CONDITIONING ISSUE
    2009 Ram 1500 Laramie with AC issues. -All actuators I can get to immediately behind dash work properly. -Compressor and belts were replaced. - Thermostat was replaced. Here is what is happening after Compressor and Thermostat were replaced. Any idea what could be causing it? AC set on Lo...
  8. 2
    AC issues
    2007 Dodge Ram, 5.7 Hemi - not able to charge AC unit. Checked operation of blower, cleaned condensor, clutch engages on condensor. Using only standard single line with gauge to charge. Gauge goes up when compressor turned off (as it should I believe) but goes to zero when compressor on. ANy...
  9. C
    Dash Knocking | AC & Heat do not work | Help
    Hello, when I first start my 2010 Ram 1500 SLT (whether the ac or heat is on or off) it starts making a sporadic knocking noise coming from the lower part of the dash in the middle (where I believe the air door actuator is). If I keep the air off or turn on heat the noise goes away after a...
  10. W
    Ac stuck on
    my AC is stuck on no matter what I do. I remove the relay in the clutch turns off. I've even swapped relays and it's still stays on when they're plugged in. Turning on the AC and turning off the AC does nothing it only turns on the condenser fan. I can't figure out why it won't respond to the...
  11. G
    AC ISN'T COOLING
    Hello from Dubai. The AC in my Dodge Ram/ Single Cabin 2015 isn't cooling anymore. Took it to 2 authorised service centres to have a look. There's no visible leaks under the hood. They say it could be the evaporator/ cooling coil which is a super expensive affair to fix out here (2,000 USD...
  12. Ghostman
    Is it Possible to run AC belt bypass for 3rd Gen Ram?
    2008 Ram 2500, 5.7 Hemi So I think my AC compressor just crapped out today. And until I can get around to fix, I would like to throw on a short bypass belt. I have found a bit of info on the 2nd Gen Rams, for adding about a 90" belt to bypass AC. I haven't been able to find any info on the...
