Starters- Truck, 2017 Ram 1500 5.7/6pd stock.
The other day on our way home from my daughters ball game, truck was running great, turned off the highway onto the gravel, gave her some good throttle kick that ass end out, however, hit a nasty pothole that I didn’t see, engine light come on...
Ok everyone i could use some help im a bit stumped and i cant find the info that will help me. I hoping someone here can. So im in the middle of swapping a 518 trans into my 2012 ram r/t. The problem im having is i cant get the key out of the ignition now. I have 5 wires grounded on the trans...
Has anyone swapped in the later model 6 speed trans or know if its possible to do so? Would I be better off swapping in an entire 6.4l and trans combo? I currently have an 05 5.7 4x4 Laramie.
Tia for any help/suggestions!
Does anyone know how to do a transmission relearn or quick learn for the 545rfe? Or have you guys just thrown a new one in and driven without worrying about doing a relearn? I am replacing my transmission this weekend in my 2010 ram 2500 5.7 since the stock is shot. The trans I got is a...
Reason I'm asking is because if I do a trans swap in my 3rd gen as a part of a performance build, I WANT a TRUE 6-speed with decent ratios and the ability to hold some good power.
From all of my reading and deductions thereof, a 66RFE seems like a good choice.
Good gear spread, true 6 speed...
