HD Guys, Is The 66RFE A Good Transmission Unlike The 65/545/45??
Drunken Hamster
Turncoat Ford Boi
South Carolina
was 2005
was 5.7 Hemi
Reason I'm asking is because if I do a trans swap in my 3rd gen as a part of a performance build, I WANT a TRUE 6-speed with decent ratios and the ability to hold some good power.
From all of my reading and deductions thereof, a 66RFE seems like a good choice.
Good gear spread, true 6 speed, diesel strength internals[68RFE], same case as my existing 545 trans, should be a similar controller...
It just seems like a good deal.
But I can't find it having been done anywhere and don't know if there's aftermarket support {manual valve bodies, shift kits, converters, finned deepwell aluminum trans fluid pans, etc.} for it or if it's even any good or if it suffers the same problems as the horrendous 65/545/45RFE transmissions.
So, I'd like to know from you HD guys, does it hold power, does it break, will it last, etc.
Thanks, guys! :D
HemiLonestar
MD
How are you going to control it lol?
Drunken Hamster
Drunken Hamster
Turncoat Ford Boi
South Carolina
was 2005
was 5.7 Hemi
Dunno, it's a hypothetical at this point. I haven't even really STARTED modding my truck aside from a few BS things like a double muffler delete and my "split level" which I'm thinking of partially undoing[the front spacers part].
But, speaking theoretically, couldn't it be controlled by a fully manual VB and floor shifter? Or an electronic VB and a dial+paddles with a standalone TCM? Or just a standalone TCM in general?
HemiLonestar
MD
Theoretically, but no one has figured out how to do so; if anyone had it would've already been a gamechanger.
Drunken Hamster
Drunken Hamster
Turncoat Ford Boi
South Carolina
was 2005
was 5.7 Hemi
I see... Are there any 6-speed swap options for our 3rd gens? Particularly those that don't involve a 3rd pedal and are TRUE 6-speeds with decent ratio spreads and evenness?
HemiLonestar
MD
Contact TCI and see if that 4L80 based 6sp they have will work in a Ram.
Drunken Hamster
Drunken Hamster
Turncoat Ford Boi
South Carolina
was 2005
was 5.7 Hemi
Taking a quick look on summit, and that's not a deep enough OD for 4.56's while at the same time not a tall enough 1st for less than 4.56's or so... :/
Guess there's kinda no option until someone does something new, huh?
HemiLonestar
MD
If you want that many gears lol
Drunken Hamster
Drunken Hamster
Turncoat Ford Boi
South Carolina
was 2005
was 5.7 Hemi
Well, if ya wanna get specific....
I want 4th gear 1:1, even spacing[that isn't wide as **** like the normal RFE's], and to be able to cruise at 65-70MPH at 2000rpm in the last gear on a 31"-32" tire.
Drunken Hamster
Drunken Hamster
Turncoat Ford Boi
South Carolina
was 2005
was 5.7 Hemi
Actually... If I stuck with 3.92's, the TCI 6x would cut that cruise speed RPM on a 32" tire according to this gearing calculator I'm using. Think is, with a 2.97 first, is 3.92 really deep enough to move out a 5k lb truck as good as an RFE on 4.56's? {{It DOES have much shorter gearing than the RFE, maybe it would make it up there??}}
NewBlackDak
Hemi 6.4L
2nd gear is **** on the 66. Go read the 6.4 thread, and you’ll see all the complaints.
NewBlackDak
Hemi 6.4L
The durability, the ratio, or both? Lol.
The ratio and 2/3 spacing sucks. I’ve had rear tires break loose on a 2nd downshift. It’s scary with a trailer or on a wet on ramp.
RoadRamblerNJ
Knoxville, TN
392 Hemi
Absolutely correct, said the 2500 HD havin' guy. This trans in my '17 2500 couldn't be more wrong as far as gear spacing, shift points etc. I'm under the impression it was basically designed for a Diesel. Not sure about that, but it ain't right for a 6.4 gasser.
RoadRamblerNJ
Knoxville, TN
392 Hemi
It likes to short shift the 1-2 at about 4500 rpm with the pedal mashed. Then 2nd lugs until you get it up into the sweet spot (4000 rpm +), 2nd revs all the way to 5500 rpm, shifts to 3rd and revs drop off too far to win any races here. By the time you get to 4th, you're approaching triple digits. And I have 4.10:1 gears. Can't imagine what the guys with 3.73s and 3.55s are seeing. There are no 3.92s in HD land.
As wrong as the trans is re: gear spacing, it has never seemed weak or unwilling to take a flogging. And the 392 just keeps pulling (pushing?) no matter what gear you're in. As soon as I save enough scheckles, I'm putting 5.13s in. I'm a little nuts that way. [My last dirt bike had a 74 tooth back sprocket (thats 28 more than stock)] It climbed trees.
Good luck Hamster Man! Ed.
SYKRAMMAN
Banned
Jersey shore
06 Mega
Holy ****! A 72 tooth rear sprocket on a dirt bike! That must be nuts riding it huh?
SYKRAMMAN
Banned
Jersey shore
06 Mega
zeddy
Burbank, Ca
Is there a fix for the spacing, shift points? Only thing I hate about my 2500.
tjfdesmo
AZ
The 66RFE basically ruins he capabilities of the 6.4, IMHO. It is a "parts bin special" using gearing for the Cummins, which could not be more wrong for a small block gas motor.
theviking
Certainly it's better suited to the Cummins, but the 66RFE gearing is actually better than any gas engine 6-speed Ram has offered prior. Ram has confirmed a new trans is in the works for HD models and it can't come soon enough. But gas mileage aside, I suspect re-gearing would resolve most people's complaints. Everyone that's done it seem to love it.
