Morning gents,
Been a few weeks since my last update. Made some good progress - finished the rebuild of the 4.7L, but then had a real pain of a time trying to get a wiring harness that would work properly.
Then I had to wrestle the damn thing into the truck. turns out the engine mounts for the V6 and the V8 are not interchangeable. I ended up getting the V8 mounts to work by cutting off a 1/2" on each side of the rubber mounts where the bolts slide through. It was aluminum so it wasn't too bad.
Moving on to getting it to start - that is another pain altogether:
As many of you know - but I didn't - the 2006 harness wasn't going to work because it used a PCM different communication system that the 2004-2005 Rams. So I had to try to make my 2005 V6 harness work with the V8. I did this buy downloading the FSMs from the 2004, 2005, and 2006 year models. I had a 2006 V8 harness, a 2005 V6 harness, and a 2004 PCM. Luckily the Pin-outs for the 2004 and 2005 are the same, so I just took the #7 & #8 injector and coil connecters from the 2006 harness and grafted them into the 2005 harness. Still though, when I plugged everything in, I had no joy. The lights would come on, but there was no action when I turned the key. Furthermore, the PRND21 on the gauge cluster would light up, but there is no "box" around any of the indicators showing that it's in a gear.
So then I was left in a situation where I didn't know if it was the harness that was causing the problem, or the PCM - as it was an unknown as well. So I lucked across another guy on Facebook Marketplace who was doing the 4.7L to Hemi swap, locally, and yesterday I went and picked up his 2004 harness, PCM, and gauge cluster.
My first test was to swap in the PCM to rule the other one out. No joy, same issue.
Then I tried swapping in his gauge cluster *shrug* maybe that'll work. And sure enough, it did...kind of.
https://photos.app.goo.gl/e7s6qECV5BoTmAfK9
*HOWEVER* while the engine did start and run, seemingly fine, the gauges are all still completely dead. No readings on any of them. Still no box around any of the gears, even though I could shift and move forward and in reverse. I wasn't comfortable letting it run for long since I couldn't see oil pressure or engine temp.
Also, I was only able to get the engine to start after shaking the wiring harness next to the PCM. And that only worked a couple of times before it stopped working. So I'm pretty stumped. Evidently there is either an issue in my modified harness or I'm missing something else that I can't figure out.
I also can't just swap the "new" 2004 harness in either, yet, because it's got a different style C130 connector. I'd used the one from the 2006, but I already did since I buggered up the C130 from the 2005 harness trying to figure out how to release the pins. Ugh.
Anyone got any ideas?
