10-ply Duratracs on Ram 1500
Yeret
The Village Drunk
Under the hood fixing/breaking something.
5.9 Magnum
I've got an opportunity to get a really sweet deal on four new 265/75/16 Goodyear Duratrac tires. I've had experience with these tires on the F350 and they had by far the best mud/snow traction of any tire that I've used across various vehicles.
These tires are 10-ply. Very heavy and very tough. Now, I don't believe that there will be a problem running these but I'm curious if anyone here is running these tires or other 10-ply tires on a 1500 and your overall thoughts. Mainly, I'm wondering what pressure you're running since these babies will take 80 psi and I'm certain I won't need to run nearly that much.
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
There are different load ratings for tires and that is really what is more important than the number of plys a tire has. For example, a load range C tire indicates that it's a 6ply tire, but it may only have 2 thick plys.
In this case you're talking about a load range E tire, or 10 ply. This is used on 2500s or greater vehicles or commercial vehicles. 1500s can use standard load range D or 8 ply tires without a problem. Since most 1500s will never see enough weight to need a load range E tire, most people won't put them on as they are more expensive and the standard D range will be just fine for most truck owners. The standard load range on tires for 1500s is 104-114 (2000-2500lbs aprox) This will handle most all loads that truck will ever see and still provide a softer ride.
Putting load range E tires on a 1500 is just fine, they are load range 122/124 or greater and rated for about 3500lbs per tire, this is great for 2500s or greater where you might have 3000lbs of equipment in the bed. I run load range E tires because I do push the limits of what my truck can haul, and because I don't want to risk a blowout going down the highway at 70 with a 7500lb travel trailer behind me, I opt for the heavier duty tire.
As far as tire pressure goes. Commercial vehicles rarely adjust tire pressure, and run them at 3/4ths max pressure at all times. This results in excess tire wear when unloaded, but optimum control and handling when loaded. As a result, I see commercial vehicles come in all the time with the center of the tires bald while still having 5/32nds worth of tread on the outside. I also see plenty of unknowing men in their 20s with big tires like the ones you're looking at with the centers all worn away because they run them at or near sidewall pressure.
The proper way to maintain the life of your tires should you get these tires, is to adjust the tire pressure to your load. The rule of thumb is 1psi for every 45lbs of weight per tire. If your truck weighs 5500lbs, thats 1375lbs per tire, so you should fill to about 30psi. If you put 1500lbs of weight in back, you should increase tire pressure to 47psi. This will help prevent unnecessary wear on the tires and maximize your investment. For comparison, the pressure per pound on a load range D tire is about 40lbs per 1 psi.
Overall, I would never put anything but a load range E on my truck, aside from the slight expense, it rides much firmer on the road and hold up to poor road conditions a bit better.
Gr8bawana
6.7 CTD
I run E load rated tires on my 1500 all the time. I do lots of hunting and fishing and light duty tires do not take the punishment of hard off-road travel. I have never had a flat or any kind of tire failure since I started using 10 ply tires. My pickup weighs about 5800lbs with my shell and stuff I carry all the time. Right now I have a set of NITTO terra grapplers in 285/75/16 and the sweet spot when unloaded is 40psi. It gives me a pretty smooth ride since I don't expect my truck to ride like a caddy. When I tow my 7500lb travel trailer I fill them up to 60psi.http://www.ramforum.com/attachment.php?attachmentid=89233&stc=1&d=1498404021
