AzRamLover
- Oct 29, 2014
- 433
- 98
- 2014
- Hemi 5.7
Went in for the airbag recall today, got bored, test drove a Tundra Platinum.
Ram: 2014 Laramie Crew Cab 4x4
Tundra: 2016 Platinum CrewMax 4x4
Conclusion: I don't feel like the Tundra is a competitive truck in today's market and I still like my Laramie more. Details follow.
Things Tundra Does Better:
Things RAM Does Better (or in most cases, Tundra is just freaking missing altogether):
I get the whole Toyota QDR (Quality Durability Reliability) argument but you've got to give up a *LOT* for that QDR. It's like saying that a knife has more QDR than a can opener so the knife will last longer and cost less to maintain.
That's probably true . . . the knife has no moving parts and can be used to open a can in a pinch. But the can opener is sure as hell more pleasant to live with.
- Resale value. No lie; Ram is objectively the worst for resale among any full size truck and Tundra is the best.
- Rear seat room. The legroom might be comparable to a Ram 2500 MegaCab. What makes it feel so nice is the 24-deg incline of the rear seatbacks; this really does feel like a BMW 7-Series long wheelbase sedan from an angle and legroom perspective.
- Rear glass retracts. Much nicer than a sliding window.
- Roof-mounted, spring loaded grab handles. Except for the driver; we'll get to that later.
- Ground clearance. The additional 1.7" is noticeable.
- Front brake calipers. 4-piston fixed and the pedal feel/responsiveness is noticeable.
- Dampened tailgate. Not available on Ram yet.
- Blind spot monitoring system. Not available on Ram yet.
- Front passenger footwell does not have transmission bulge. This drives my wife nuts in my Ram.
- Projector beam headlights. If you want to convert to HID, this is doable without being obnoxious (light cutoff). Tundra has reflector halogens and they suck.
- Dead pedal under parking brake. I hate these things bc I find them so uncomfortable; it's not removable, either.
- EVIC. Tundra has all of 5 pieces of info, which can only be displayed one at a time on the tiny screen: current fuel econ, avg fuel econ, DTE, driving duration, trailer brake gain. It's positively 2000s tech. No transmission temperature, oil temperature, or oil pressure info available.
- UConnect has a bigger (8.4"), 3:4 screen. Tundra has an 8" screen but it's 16:9 (the movie aspect ratio), which sucks for navigation.
- Interior storage. Tundra has no under floor storage and no under rear seat storage. And only 2 cupholders in the rear armrest (as opposed to the additional 2 cupholders on Ram's floor).
- Fold out flat floor. Not available on Tundra.
- Driver A pillar handle. Not available on Tundra. No roof mounted handle either. I guess you're just supposed to use the steering wheel. WTF, Toyota?
- Center console has cutouts for cord. Tundra does not.
- UConnect plays media files off of both USB & SD card. Tundra does not support SD card.
- Gear selector knob frees up space. Tundra has console mounted shifter that takes up space. I'm not sure why we needed to go from column mounted to something else but whatever.
- Transmission. Ram's 8HP70 is better than Tundra's 6-speed.
- Fuel economy. Ram 15/19 (my personal actuals) VS Tundra 13/17 (EPA)
- Acceleration. The magazines say my Ram is around 7s flat 0-60 w/ 3.92 gears (I have 3.21s so I'm slower) & the Tundra is supposed to do it in 6.4s. Certainly did not feel that way.
- Engine sound. Ram sounds like a hot rod. Tundra sounds like a vacuum cleaner.
- Dual exhaust. Ram wins this on aesthetics but that's just me.
- Rear end ratio. Ram gives you choice; Tundra is 4.30 only.
- Backup camera. Ram has high resolution, with moveable tire path lines. Tundra has a crappy, low res camera, with no moveable lines.
- Wheels. Ram can be downsized to 17". Tundra is 20" only (Platinum).
- Ride quality. Ram rides like a luxury car. Tundra still rides like a truck.
- Remote locking tailgate. Ram wins. Tundra requires a freaking key.
- Remote start. Ram from the factory; Tundra optional, potentially dealer-installed.
- Tow mirror options. Ram has optional tow mirrors. No one at the Toyota dealer even knew about tow mirrors.
- Auto dimming side view mirrors. Not available on Tundra.
- Proximity key and keyless ignition. Not available on Tundra.
