TOMZILLA
Ok so I have a 2017 1500 standard cab 2wd hemi that I lowered with the Belltech 2/4 spring/shock kit. I retained the stock front shocks. Also has 22" wheels with 305/40/22 front and rear.
Now the problem I'm having is at 65+ mph I get a vibration though the whole truck coming from what seems to be the rear portion of the truck. The vibration is odd that it is 3 seconds on then 1 second off then 3 secs on over and over..... Until the speeds drops below the low 60's.
I can see my rear axle is slightly forward in the wheel house. I do have the panhard relocation bracket installed. I've been reading about the pinion angle being off due to lowering and may be the cause of the vibration. If it matters my driveshaft looks to be a 2 piece. There is a rubber accordion boot in the center of it. Maybe they all do...
I'm sure others have had this issue. What has been the fix? Adjustable control arms?
