flecker
Hi, first post here... I did search but couldn't find an answer to my question.
I have a 96 Ram 1500 with a 5.9L. The engine was replaced prior to me having worked on it with I believe a 360 from a later year. There is only ONE boss for a temp sensor/ sender location. My harness has a plug for a sender and a separate plug for a sensor (one that feeds data to ecu). I currently have the sensor in use and plugged in, the other sender for the gauge just dangles currently and the gauge is inactive. What are my options here? I see the location where the other boss for the sender would/ could go. Will I need to drill and tap? Or is there a different sensor I could use and modify the harness to work?
Halp! Thanks in advance for any advice or info.
