2000 Ram 5.9 4wd computer work with a 1996 2wd transmission?
brushwolf
MN
No experience with the Mopar AOD transmissions. Want to do an engine and trans swap on a fifties Dodge car and have a 2000 lower mile 5.9 Magnum, computer and wiring harness from the 4wd Ram that had bad trans (and which is gone). But, I have a good 2wd 1996 Ram transmission. Will this computer work with the 4 year older transmission as plug and play or if not, what will I need to change so I retain the OD function? Thanks
