2002 ram fuse box wiring/ fuse #51 help please...
Discussion in 'Audio & Electronics' started by Sohc1997, Jul 1, 2016.
  1. Sohc1997
    Sohc1997 Junior Member
    25
    11
    Jul 1, 2016
    Ram Year:
    2002
    Engine:
    5.9L
    I just purchased a 2002 ram 1500 quad 5.9 4x4, no power to anything with key off. I Checked all fuses, pulled every plug from fuse box and clean the pins. Looked at wire harness and can't figure it out. Fuse 51 is good, I've search for 2 weeks and can't figure it out, there is also no radio or power to obd port for scanning. Any advice would be appreciated, thanks.
  2. Sohc1997
    25
    11
    Jul 1, 2016
    Ram Year:
    2002
    Engine:
    5.9L
    Well I figured it out, the pink wire in pin #16 obd port is the power lead witch ties into everything for fuse #51. That wire is #9 in the green plug for fuse box, it's was corroded and broke off the pin. All is good now!
  3. justin13703
    justin13703 Senior Member
    28
    1,006
    296
    Oct 15, 2014
    MD
    Ram Year:
    2008
    Engine:
    Good work finding that, problems like that can be a nightmare
  4. Hot Ducer
    Hot Ducer Senior Member
    167
    29
    May 3, 2016
    Atlanta Ga
    Ram Year:
    2003
    Engine:
    Right and thanks for posting your results!
    2003 1500 QuadCab 5.7 4x4
  5. TemagamiRick
    TemagamiRick Junior Member
    58
    Sep 25, 2016
    Ram Year:
    Engine:
    Magnum 4.7
    Thank you so much for posting. Same problem has been driving me crazy all summer.
    2004 1500 SLT QuadCab 4.7 4x4
    Sent from my LG-D852 using Tapatalk
Share This Page
