gearhead
Hi Guys,
I have a 2003 4.7 2wd. A few months back the truck threw P0302 code. So I thought lets eliminate the obvious first. Checked the plugs and they were nubs! I had no idea this truck had copper plugs and it went 60k on factory plugs. I swapped them out and cleared the code and it was gone...for about 6 months. Well, now it is back, same code. So I though maybe it is a coil and plugs were just by chance bad as well. I swapped the #2 coil with #1 coil, cleared the code and waited to see. Well, it popped back up and its the same code, so not a coil.(Damn!)
Info on the truck: I am second owner, truck has 71,000 on it now. This ruck sat for about 5 years while owner was in jail, or so I am told. Since it sat for so long it does have a noisy lifter on start up but that's about it. I have found if I don't turn the key and let the fuel pump run it has a very hard time starting. It has been this way since I have owned it, so I just always let the pump run first.
The latest: The only thing I can different is every now and then if you are sitting idling you feel a miss. Feels like a quick kick where the truck gives a little jolt. RPMS on dash don't seem to move its just a slight miss that you feel. Other than that, no issues.
I need your help with this, let me know if anyone has any experience or can think of anything. I had thought it could be fuel related from sitting so long or maybe a clogged injector but kind of weird to be only one cylinder throwing a code. Let me know what you guys think, I hope this is enough info to fill you in and get the juices going! Thanks!
