Robert Leon
- Nov 2, 2014
- 102
- 14
- 2005
- 5.7
I think it could come on if the battery is getting too hot from charging too, since there is that sensor under the battery.
That sensor under the battery is not to monitor battery temp for regulation purposes. It is just another reference for ambient temp. Has nothing to do with the battery light.
The BTS is used to determine the battery temperature and control battery charging rate. This temperature data, along with data from monitored line voltage, is used by the PCM (ECM Diesel) to vary the battery charging rate. System voltage will be higher at colder temperatures and is gradually reduced at warmer temperatures.
The PCM sends 5 volts to the sensor and is grounded through the sensor return line. As temperature increases, resistance in the sensor decreases and the detection voltage at the PCM increases.
The BTS is also used for OBD II diagnostics. Certain faults and OBD II monitors are either enabled or disabled, depending upon BTS input (for example, disable purge and enable Leak Detection Pump (LDP) and O2 sensor heater tests). Most OBD II monitors are disabled below 20°F.
Read more: http://www.justanswer.com/dodge/110cx-test-battery-temperature-sensor.html#ixzz3KCCDhX00
