2005 Ram 1500 4.7L not charging code P0622 in computer
sam37806
4.7 liter
I have a 2005 Ram 1500. The battery is not charging. " Check Gauges" light on cluster stays on. So far, I've had the alternator tested, put in a new battery, ordered a rebuilt computer and installed it, and ran the code test which gave code P0622. I also ran the gauge test and got codes AA 10, and AB 10. What is the AA10 and AB10 meanings, and what should I try next? The computer I replaced was the one mounted at the firewall on passenger side secured with 3 screws and has 4 plugs. Any help is much appreciated.
Black Betty
Alaska
Did you get this figured out? I'm having the same issue in my 2003 Ram 1500 5.9 liter.
clueless
2021 bighorn 5.7 hemi
was the pcm module programmed? also did you ohm out the wire from the 2 wire plug to the pcm? had a issue with my 07,found a 06 alternator has a different plug than a 07 and wires are different in the plug also.
Jems007
