2007-2008 Dodge Ram 1500 Truck Front & Rear Performance Cross Drilled & Slotted Zinc
1ATony
Preferred Vendor
hemi
SHOP HERE 2007-2008 Dodge Ram 1500 Truck Front & Rear Performance Cross Drilled & Slotted Zinc Coated Brake Pad & Rotor Kit Premium Posi Semi-Metallic (excluding SRT-10 & Mega Cab)
FREE SHIPPING
Brake Pad Specifications:
  • Premium Posi Semi Metallic brake pads
  • 8 Piece Front & Rear brake pad set
  • Includes shims
  • Direct replacement
Brake Rotor Specifications:
  • Comes as a set of 4
  • Includes both LH (Driver) & RH (Passenger) Side FRONT & REAR
  • Cross drilled, Slotted, And Zinc Coated
  • Fits 5 Stud Wheel
  • Front
  • 13.2" (336mm) Diameter
  • Rear
  • 13.86" Diameter
Premium Positive Molded Brake Pads Features and Benefits:
The very same manufacturing process the original equipment manufacturers use
High density friction material for long pad life
Less resin content virtually eliminates brake fade and glazing
Reduced dusting for both Ceramic and Semi-metallic materials
Quality multi-layered shims and pad chamfering provide smooth and quite braking
ALSO FITS THESE VEHICLES
VEHICLE FIT
  • 2006 Dodge Ram 1500 Truck Front & Rear Performance Cross Drilled & Slotted Zinc Coated Brake Pad & Rotor Kit Premium Posi Semi-Metallic (excluding SRT-10 & Mega Cab)
  • 2007-2008 Dodge Ram 1500 Truck Front & Rear Performance Cross Drilled & Slotted Zinc Coated Brake Pad & Rotor Kit Premium Posi Semi-Metallic (excluding SRT-10 & Mega Cab)
  • 2009-2010 Dodge Ram 1500 Truck Front & Rear Performance Cross Drilled & Slotted Zinc Coated Brake Pad & Rotor Kit Premium Posi Semi-Metallic
  • 2011-2013 Ram 1500 Truck Front & Rear Performance Cross Drilled & Slotted Zinc Coated Brake Pad & Rotor Kit Premium Posi Semi-Metallic
Orca
