2010 1500 Park Assist Module Location?
codyfelkins
oregon
my 2010 dodge ram 1500 sport has park assist. There is a message popping up saying I need to clean the sensors. I tried doing that and it didn't fix anything. I went ahead and replaced all the park sensors and it keeps saying I need to clean them. I read that it could mean the module needs replaced. I have googled to try to locate where the Module is located but no luck. Does anyone know where it is located?
Dean2
Near Edmonton
Also, did you use oem sensors, or ones with the same resistance values if you bought aftermarket. Bosch, who maes the oem ones, does make sensors you can buy much cheaper than oem.
You also want to use an obd reader to clear the code to see if it comes back on before doing any more work.
