2011 ram fuel pressure
Mckee1492
Pekin il
I have a 2011 ram 1500 with the 5.7. I have to cycle the key like 20 times to get it to start. I’ve replaced the fuel pump. Idk where else to go. I think it’s the fuel pressure regulator. But idk if it’s on the fuel rail or the pump. But if pump is new the regulator should be too right.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
can you hear the pump when you stand by the right rear tire & remote start it ?
If not, try replacing the fuel pump relay
if that does not help, you have a spare relay to keep with your spare fuses
cycling the key like 20 times to get it to start, could also be the ignition box
M
Mckee1492
Pekin il
It will try to start with out cycling key but like it’s got no fuel. I don’t think it has fuel at the fuel rail. But cycling it builds pressure to get fuel to the rail
