2015 6.4 5500 no torque ??????
Twduck1972
Vallejo ca
Cummings 6.7
I need help here please. I Have a 2015 5500 ram fleet package with the 6.4 himi and the ansni tranz. I seem to get decent gas mileage
8-10 mph on flat hwy and it seems to drive fine but going up hill it has no torque for pulling. I'm getting anywhere from 6 to 6.5 miles per gallon uphill. And on a steep slope like by hoover dam it was going 30 miles an 4000 RPM. Towing 4000 pounds plus 7000 pounds trailer. Is this possibly a fuel filter issue a computer issue or is it just the fact that I'm running a gasoline mutter doing a diesel motor's job.
06 Dodge
Forest Grove, Oregon
6.7L CTD
Sounds like someone believed what the salesman said about how much better the Hemi is and and how its some how better then a Cummins except then it comes to towing fuel mileage & going up a grade loaded... IMHO yes you need a Cummins in that 5500..
Twduck1972
Twduck1972
Vallejo ca
Cummings 6.7
No i know not to beleive pretty much anyone outright. The 5500 was the only one around when i had to get it. So i got it i just didnt think it would cost 800 to go from Az to Sparks.
tjfdesmo
AZ
The 6.4 is a small block gasser, and it needs RPM to get it done. I pulled a toy hauler with my 2015 that was saddled with the 66RFE trans, and scaled at 23,160 lbs. It was working hard, and had to really wind out. I averaged about 7.5 mpg pulling at 65 mph. Elevation really makes it wheeze, being normally aspirated.
Bottom line: if you want to have relaxed, steady towing up hills, and easy, stress free descents coming down the other side there is nothing, repeat NOTHING like the Cummins.
