2015 ram 1500 fault codes
grunion
Puyallup, WA
Hello,
I recently did an engine swap on a 5.7l 1500 2015. After it was done it started up just fine but sent some codes and a check engine light. We've done a lot to find the issue but with luck. In wondering if anyone can help.
We've replaced the alternator, the fuel injector, the fuel injector connector (spliced in a new one), the PCU wiring covers.
We've checked the battery which is good.
We've checked what we believe are all the possible associated fuses in the fuse box and on the battery terminals which all seem good.
Our current theory is either the PCU is bust or there are some faulty wires in the wiring harness.
Any thoughts/help would be appreciated!
Daw14
Did you miss some ground connections ? There are a lot .
G
grunion
Puyallup, WA
We did our best to find all we could and none seemed loose or disconnected
