SKYLER POSTON
Bear with me because this only happens in very specific circumstances.
My truck has had a long crank starting issue intermittently but now its a daily occurrence.
I leave for work at about 5 am and in Yuma, AZ right now its about low 60s. My truck starts perfectly and drives perfectly. I drive about 50 minutes at 65mph with maybe 3 stop lights between home and work. About 30 miles with turns and curves. I park my truck at 6 am and go out at 4:30 in the afternoon and it's now the low 80s. The truck takes a good 5 seconds to start. just cranking for 5 seconds. I drive home and park it over night and it starts just fine in the morning! Also if I drive it anywhere else after work, like to eat or movies etc. then drive home, it always starts fine. it just that one time sitting in the sun each day that it won't start correctly. Today I went out about 10 am and it started fine. I went back about noon and long start. I went back about 3:00 long start. I'm betting at 4:30...long start.
I've already cycled my ignition with 5-10 sec intervals on auxiliary to see if the lines are losing fuel due to a bad gate valve in the pump (thinking maybe the lines are draining back into the tank) but the hard start is still there.
I took it to the family mech and they couldn't replicate the issue in order to run a diagnostic on it. He did get a gas cap error code and cleared it and then said maybe the cpm need to be flashed by Dodge...?
No other mechanical issues other than cruise control not engaging sometimes but I'm pretty sure that's a connectivity issue in the column.
38xxx miles
38xxx miles
