2016 Ram 2500 EGR valve TSB
opie
Let's say I'm rolling up to a red light that I know is going to turn green before I stop. So as
I'm coasting towards the light feathering the throttle just to maintain momentum I can feel some type of disconnect in the output. It's very subtle.
Sent from a field
U&A
2016 3500 SRW
6.4 HEMI
Sent from a field
Strange? Have you tried to change somthing to see if it still happens? I would just try a full tank of a different fuel octane then what you normally use. Probably won't make any difference but I would do it just to see if it does.
Also does it do it when you're in tow haul mode? Or using the gear selector? Say you put it in fifth while driving around town so it disables MDS see if it does it as you slow down then.
opie
Haven't tried to reproduce it. It's subtle enough that I know a service advisor wouldn't notice it so I haven't done anything about it.
Sent from a field
2robinhood
2016 Ram 3500 SRW crew cab
6.4l gas
So anyone have the TSB number for the EGR ?
y 2016 Ram 3500 with the 6.4 does the surging at light throttle .
