mitch42
I have a 2017 ram 2500 6.4 that at times it will not start or runs very rough if does. If it does not start it will just spin over until I turn the key back then it will start right up. A few times it would start and act like it was running on 4 cylinders and I can shut if off and restart and it will run fine. It usually will do it after I have been driving it and then let it sit 20 or 30 minutes and try to start it and it will act up. It does not do this all the time, it might run perfect for a few weeks then do this out of the blue.Also the check engine light never comes on and it has never set a code. I thought it could be the tipum so I ordered one of those and swapped it out and the next day it did the same thing. Anyone ever ran across this.
Thanks
Thanks
