2018 RAM Security Module Bypass
DeereGuy
Preferred Vendor
Pittsburgh, PA
Now taking orders for RAM Security Module Bypass Harnesses. If you have a 2018 RAM or a 2019 RAM Classic and would like to perform diagnostics or make changes to the modules of your truck using tools like AlfaOBD or AutoEngenuity, this bypass is for you. Cost of the bypass is $55.
In order to facility the ordering of the bypass, I have created a website for the orders. Please visit www.securitymodulebypass.com to order a bypass.
FAQ
Does this allow access to all modules?
It has been tested connecting to the BCM and RFH. Since it bypasses the security module for both the CAN C and CAN IHS, almost all modules should be good. The one exception is the radio. The radio does not directly connect to the either CAN of the truck, it is hung off of a DMZ on the security module to protect the truck's CAN in case the radio would be comprised via the 4G cellular functionality.
Does this work with 1500, 2500, 3500, etc?
There are two different versions. One for the 1500s, and one for 2500s and up.
How long does it take to install and is the install permanent?
It take about 5 - 10 minutes to install. Installation instructions will be provided with your purchase. It can be removed in the same amount of time. The factory OBD2 port can be put back in place in less than 2 minutes without any tools.
What programs have been tested with the bypass?
At this point, AutoEngenuity, AlfaOBD, and Autel have been used with the bypass.
Should I leave the bypass installed at all times?
That is up to you. Installing the bypass does make the truck less secure by enabling the OBD2 port for use with diagnostic and configuration utilities not provided or authorized by FCA. That being said, the harness rewires the truck to be just like all previous model year RAMs. I would recommend that you remove the bypass before taking it to a dealer.
Can I use this on multiple trucks?
Yes. We have sold several of these already to dealers and third party shops who work on RAM trucks.
R.L.K.
Bristol , Tn.
That is Awesome !!
jmant230
I will take one for my 2500. I will PM you.
Great work as always.
Gibbs
GA
6.7L Cummins
I need one of these harnesses, please. PM sent. Thanks!
Joe B
U.S. Navy Chief
Pensacola, FL
Cummins 6.4L
Looks like I will also need one of these. PM coming your way.
rreavis
NC
Will this work with a 2017 2500?
Bowzer
Sold off the '18...maybe another soon.
I'm in! Message sent over to you...
Joji91
Would the harness work on a 2018 charger?
Lawsuit11
Fort Worth, TX
Now taking orders for RAM 2018 Security Module Bypass Harnesses. If you have a 2018 RAM and would like to perform diagnostics or make changes to the modules of your truck using tools like AlfaOBD or AutoEngenuity, this bypass is for you. Cost of the bypass is $45.
FAQ
Yes. We have sold several of these already to dealers and third party shops who work on RAM trucks. If you are planning on using the bypass on multiple trucks, let us know and we can customize it so that it is easier to use on a temporary basis.
I ordered my security Harness through Mike along with my 7 spd conversion harness and I just wanted to thank you for everything that you are doing, along with working with mike and doing what you guys are for the Ram Community. Could do it without you or Mike. I would be a lost soul trying to figure it out myself lol
Lowrider357
