2019 Technical Service Bulletins (TSBs)
dreinert
Wisconsin
2019 Ram Limited
Anyone have a list of TSBs available for the 2019 Ram?
I found these but there must be others. It's my first time with a Ram so I don't know whats actually normal or unusual and I'd hate going to the dealer everytime I "feel" like there's an issue or something that could be improved.
September 28, 2018 - Flash: Blind Spot Monitor System Updates - # 08-125-18
Fixed my blind spot monitoring issue that showed a "service required" message
September 18, 2018 - Flash: Amplifier Enhancement - # 08-123-18
Apparently for the HK stereo (maybe only 12"). It atleast makes the sound louder.
September 15, 2018 - Flash: Anti-Lock Brake System (ABS) Module Diagnostic and System Improvements - # 08-118-18
I think related to people having the brakes apply hard unexpectedly when backing up.
September 11, 2018 - Flash: Drivetrain Control Module (DTCM) Diagnostic and System Improvements - # 08-116-18
Sounds like it's atleast for hard downshifts experienced.
Date: November 8, 2018 - TSB 23-047-18
Subject: Noise from A-Pillar or Floor Area During Turns or Body Movement
Symptom: Customer may describe popping or cracking noises heard around the front floor or A-pillar area, while turning left or right (during lateral movement).
ORTVK
Delaware
Just bought my Ram Rebel this weekend. Funny enough i do notice the popping sound described. Other then that so far so good!
sman301
Canada
Its would be nice to have all the TSB in one place. I currenlty have a few issues with my new 2019
aldaran
Wondering if anyone has experienced a rear end growling/groaning sound with some vibration? The dealer said it was normal and that the cause was the muffler breaking in. However, the noise has gotten louder especially in cold weather. I did see a recall for some trucks that left the factory with insufficient differential fluid. Any advice would be greatly appreciated.
Lettikka
North Carolina
There was a guy keeping a very nice detailed list of the TSB's that came out for the 2019's. It is difficult to find and I am going in for service next week so I am looking for it. If you keep poking around you will find it. I HOPE.
Ram19 Owner
Burlington,Iowa
HEMI 5.7
Hope this helps. Found this on another site.
Huge thanks to @96Dodge4x4 for keeping us updated on TSBs & Recalls.
Updated February 17, 2019:
Body
Body
December 18, 2018 - Overhead Console Inoperative - # 23-052-18
December 12, 2018 - Steering Column Opening Cover Color Mis-Match - # 23-049-18
October 20, 2018 - Lower Body to Wheel Flare Paint Mismatch - # 23-044-18
November 8, 2018 - Noise From A-Pillar or Floor Area During Turns or Body Movement - # 23-047-18
July 11, 2018 - Mixed Rear Seat Trim Covers - # 23-030-18
June 27, 2018 - Hood Vibrates, Shakes or Flutters While Driving at Highway Speeds - # 23-029-18
Brakes
February 14, 2019 - Rear Brake Noise - # 05-001-19
Differential and Driveline
February 2, 2019 - Front Axle Noise While in 4WD Mode - # 03-001-19
Electrical
January 26, 2019 - UAX and UCX Radio Enhancements - # 08-009-19
December 4, 2018 - Flash: Hybrid Control Processor (HCP) Updates - 08-139-18 REV. A
December 4, 2018 - Flash: Powertrain Control Module (PCM) Updates - # 18-077-18 REV. A
November 5, 2018 - Radio and Back-up Camera Enhancements - # 08-091-18 REV. C
October 25, 2018 - Flash: Active Noise Cancellation (ANC) Module - # 08-140-18
October 23, 2018 - Flash: Hybrid Control Processor (HCP) Updates - # 08-139-18
September 6, 2018 - Map Pocket Lights Inoperative - # 08-112-18
August 25, 2018 - UAX and UCX Flash Over The Air (FOTA) Radio Update - # 08-110-18
July 27, 2018 - UAX and UCX Radio Enhancements - # 08-098-18
July 12, 2018 - Radio Over the Air Software Version Updates - # 08-093-18
July 11, 2018 - Radio Enhancements - # 08-091-18 REV A
June 23, 2018 - Drone or Booming Noise from Audio System - # 08-088-18
June 26, 2018 - Navigation Inoperable - # 08-087-18
May 26, 2018 - Flash: Parktronic System Module Enhancements - # 08-076-18
May 12, 2018 - Tilt Side Mirrors Inoperative with Memory Function and when Vehicle is Shifted into Reverse - # 08-069-18
April 24, 2018 - Rear View Camera Inoperative - # 08-055-18
July 31, 2018 - Engine Oil Consumption Guideline - # 09-007-18
Heating and Air Conditioning
February 15, 2019 - Flash: HVAC Diagnostic and System Updates - # 24-001-19
July 13, 2018 - A/C Systems Contain Fluorescent Leak Check Dye in Factory Fill - # 2400818
Miscellaneous
September 21, 2018 - Fluid Flushing Requirements - # 26-001-18
Steering
October 30, 2018 - Clunk Felt in the Steering Wheel - # 19-002-18
Transmission and Transfer Case
December 4, 2018 - Flash: Transmission Control Module (TCM) Updates - # 21-050-18 REV. A
October 23, 2018 - Flash: Transmission Control Module (TCM) Updates - # 21-050-18
August 23, 2018 - Transfer Case Range Position Sensor - # 21-042-18
April 12, 2018 - Flash: Transmission Diagnostic and Shift Enhancements - # 21-021-18
Vehicle Performance
December 4, 2018: Flash: Powertrain Control Module (PCM) Updates - # 18-077-18 REV. A
October 19, 2018: Flash: Powertrain Control Module (PCM) Updates - # 18-076-18
October 23, 2018 - Flash: Powertrain Control Module (PCM) Updates - # 18-077-18
Ram19 Owner
Burlington,Iowa
HEMI 5.7
Here is a list I found on another 5th gen ram forum site. Look that up (hint hint)
Tsb’s listed in previous post above.
Barney556180
Don't need no stinkin' mask...
Northern Michigan
Have only about 350 miles on my 2019 Laramie Hemi. Today I heard a strange mechanical growling/groaning kind of noise from somewhere in the middle of the truck shortly after parking. Lasted about 3 seconds.
Never heard anything like this from any vehicle... Now waiting to see if it happens again.
xtreme762
My 2019 Rebel 12 does the same thing. I've heard it a few times now. Doesn't do it all the time, though. So no idea what it could be.
GeekDaddy
Illinois
Thanks for posting those TSB's! I recently went to change the oil on my 2018 Power Wagon and found it was a quart low, and had puffed blue smoke a couple of times. The dealer said they can't find any traces of oil burning, BS, and then sent me the TSB above on Oil Consumption, so good to see the details. Seems 1 quart every 2000 miles is ridiculous. I might as well just carry a case of oil with me. At $10/quart too it'll be hard justifying driving this thing soon. Anyone had luck getting this fixed and have suggestions?
stealthprospector
Los Angeles
I6 Cummins
Does anyone know of any TSB's for sound system issues on 2020 models? The HK system in my 2500 sounds weak and the dealership is saying the above has already been implemented?
CSI-INDY
INDIANA
5.7 L HEMI
Hi I'm unsure if this is the same as you're hearing/experiencing, my 18 RAM 1500 Longhorn has a weird mechanical groaning sound in the cabin area with truck turned OFF & it is intermittent but continuous! From in the passenger side front door inside I hear this (I have bad ears but I can't hear from the outside of the truck). When I asked the dealership about it I got shrugs.
Orca
