2021 Ram 1500 Classic Regular Cab 2WD 5.7 Colorshift paint build
Froddoyo
Froddoyo
Alberta, Canada
2021 Classic
Center console swap
alright so its time to share the console swap procedure! many of these pictures were taking months apart from eachother, I just wanted to have everything completed before posting about it.
Heres how it went.
For the console itself I found a used one through a wrecker. its not in the best shape and I'm pretty sure they had it sitting outside for a bit. I tried to find the best one possible but they seem to be quite rare.
Also the only arm rest color i could find was grey.. I was hoping to find a black or leather one. but I could swap that in the future.
The upper part of the console. like the stereo bezel I have actually had laying around for years. We swapped one on a truck because it had a little nick of damage in it from a moose hitting a windshield.
No worries though. We will be fixing it. I had this bezel WAAAY before even planning on building a 4th gen. Guess it came in handy.
Opening this puppy up I was given a little surprise. THIS THING IS FIIIILTHY!! DDDAAAAYUUUMM. I had already paid for it and there are no returns on these parts so I had to work with what i had.
Alright so this photo here shows the wiring that came with this console. I did try plugging it into my truck but my truck is just incompatible with this wiring setup.
I don't know for sure but it seems like the Classics have a similiar (but not the exact same) wiring as the non classic 19+ models.
this console is clearly from a 13(14)-18 model.
So at this point I am pretty much forced to use the wiring and hub from the existing middle seat. which is fine. I got this :cool:
I am not going to explain too much here. the photos speak for themselves. I tried to do this in the cleanest way I could think of possible.
Here is the original middle seat from the truck. I tore the thing completely apart and gutted the wiring out of it. and put it back together.
The new hub that will be going into the console.
here's what the hub looks like on the console. clearly I have to do some custom work here to make things fit. And yes I did clean up the plastic :p
Taking apart the console to gut the original wiring.
paper template.
Rough cut some plastic out of an old broken bumper.
Lots of dremel work later.
First coat of rubberized undercoating. Trying to give it a somewhat factory appearance.
couple dabs of 142 fusor glue to put it into place and the hub slid in and clicked into place perfectly.
Froddoyo
Froddoyo
Alberta, Canada
2021 Classic
Bath time!!!! (I had actually done this cleaning sometime in-between installing that hub form the previous post)
I only caught a picture of these parts but the actual center console itself also got a washing.
It looks 10x better!!
routing the new hub wires into the console.
(this photo was of course taken before I removed the center seat. Just putting the photo here to show the process)
Passenger seat removed and center seat removed. Driver seat unbolted and just moved over an inch. It doesnt necessarily need to come right out.
This seatbelt latch can of course come out cause we will no longer have a center seat.
This is why the driver seat needed to be loosened. to remove this seatbelt latch.
So in this photo you will see two new brackets. one behind the airbag module another one up front. THOSE ARE REQUIRED FOR THIS.
So if you get a center console from a wrecking yard be sure to also get these brackets. I forgot to and ended up ordering new ones from mopar.
I probably could have got them from the wrecking yard but after I spend the time driving and spending the gas money it just wasn't worth going back for them.
All vacuumed up!
did a test fit. then removed the console again and gave it one more good wipe down so its clean.
When installing the center console I realized a screw must go here but there was no clip for the screw to go into.
much better!
Didn't catch a photo of the console installed. but I do have photos of the final installation.
Froddoyo
Froddoyo
Alberta, Canada
2021 Classic
Repairing some nicks.
Primed them with a UV primer. didnt catch a photo. but its nothing too exciting.
Sanded with 600 grit by hand and a red scotch brite pad.
1 coat of black epoxy as a sealer. and 1 coat of pxj black (without the glass flake added)
I masked the trim and painted the rest with 5 coats of chameleon.
Cleared with a full matte finish. I want these to be both flashy but also subtle. I think I nailed it.
Ok so for anyone that doesnt know. You cannot use the bezel from a bench setup when installing a console.
if you look at the bottom they are very different.
However. all the hardware within these panels is fully transferable!!
This photo came out super blurry. my bad.
Alright so its like 99% done. I am missing the kicker panels for it though :(
Another thing I had forgotten to grab from the wreckers. and new ones are insanely expensive.
but that's a low priority thing right now. I will grab some when I get a chance.
Froddoyo
Froddoyo
Alberta, Canada
2021 Classic
Tailgate (with rear badge shave)
Hello guys! here to show you the tailgate
The following photos you see are throughout 3 weeks. Giving every step great cure times.
Imma just say- Getting this badge shave to look normal on a curved gate was pretty hard.
All Hardware removed
2 sided tape removed with eraser wheel.
making a quick stencil
Found a hood with a flat surface. chevy avalanche hood. made slightly larger and rough cut from it.
trimmed it down to fit.
grinded both sides.
spread on both the patch and on the patch.
So this is my first time using a panel adhesive
Honestly this was the only thing I could find to clamp it. also after I took this photo I actually put a bit more weight on it.
the next morning after i just ground down the glue a bit on the edges.
a bit of spraybomb etch primer and stored for over a week. I want to give this stuff the best chance possible to cure before filling.
after letting it sit. ground down the area.
Using a fibreglass filler.
Body filler. trying to keep this stuff thin.
Sanded down to 320 grit.
etch primer.
3 coats of PPGs new (march, 2022) ECP35 primer. planning to burn through and reprime.
couple days later
Same primer, 3 coats.
More days pass. I flip it over and spray the jambs.
This also gave it a chance to bake the primer on the front.
Froddoyo
Froddoyo
Alberta, Canada
2021 Classic
Prepped for Raptor Liner Bedliner.
Many days later. had to let the bedliner cure well before flipping.
3 coats of pxj black. (with no flake in it)
5 coats of chameleon. 3 coats of 550 clear.
I blew this one with a kiss right after that 3rd coat of clear.
Froddoyo
Froddoyo
Alberta, Canada
2021 Classic
The Bed
Sanded down with 800 grit and grey scotchbrite
Started this paintjob at 10:30PM, was at the shop until 1:30am. was a late night (Can't turn bold lettering off here dunno why?)
5 Coats of Chameleon basecoat
did end up getting a bit of a run and a dirt nib on the fuel door. hopefully we can easily fix that later.
Froddoyo
Froddoyo
Alberta, Canada
2021 Classic
Rear bumper and tailgate assembled.
Also did some tail lights. these are fill ins until I get my hands on some 5th gen HD lights.
I gave my co-worker my brand new lights and took his used ones in his truck and did some paint work on them.
I'd rather paint a pair of old taillights and let him enjoy the brand new ones :)
I smoked them with translucent basecoat, then masked for the borders. painted the borders. then dusted a very light coat of chameleon over the whole thing.
They seem pretty opaque but I gave them a test and with a really bright LED in them I think they'll be good.
I'll test them in broad day light and if they seem dangerous I'll sand them down and do something different.
So. GOOD NEWS. IM DONE PAINTING! the rest is all assembly and suspension work!! wooo! hundreds of hours and late nights later we are here.
emjohn4
Amazing job!
I've painted exactly 1/2 a car (the front half, to be specific) in my life. Posts/images like this remind me why the number of cars I've painted will never increase beyond 1/2.....you're an artist!
Froddoyo
Froddoyo
Alberta, Canada
2021 Classic
20220327_172819.jpg20220327_172832.jpg20220327_172835.jpg20220327_172903.jpg20220327_172924.jpg20220327_172933.jpg20220327_172937.jpg20220327_172941.jpg20220327_172948.jpg20220327_173325.jpg
So I'm still missing the bed caps. unfortunately these newer ones are near impossible to remove without breaking. So I have to get new ones. :(
Here is a video that shows even more details. :) Enjoy!
EdGs
FL
Damn, that is one awesome looking job. 6 months is a long time, but it really looks sharp!
Dinky
Oregon
Looks great now its time for some black wheels and level/lower it.
Dinky
Oregon
Black wheels would look nice. I was also thinking maybe a dark bronze color.
Dark bronze would look ok. I would definitely have someone photo shop it for your and see what looks best.
JustinRam1500
