In my area Fred Meyer/Kroger does not charge extra for using CC nor does the 76 station just down the street but Arco, Shell, Chevron and truck stops sure do, when I travel I try to not buy from places that want 10 for using CC but when I have to its nice as I buy all my fuel with my Citi Card because I get 4% rebate on all fuel purchases up to $7500 year..Does everyone pay with a card ?
At most of the stations i see in my area, stations charge 10 cents per gallon when you use a card.
There are very few places that just have a 35 cent charge for using a card,
I think that i am going back to paying cash, just have to find the ATMs that don't charge $3.00 to use the machine
That site is so messed up. There's no way you can trust it. Build sheet, window sticker, and the tank itself say it's 33 gallons. This is what I see on the website...Like I said I went to the RAM website. Heres pictorial instructions.
If the big bed come with bigger tank, that makes the long bed a no brainer doesn’t it? It’s like $100 for the longer bed or something…
If you have a Costco close by, check and see if they are carrying diesel. Many of the newer ones do. Mine has B5. They are the cheapest in the area, cards only and if you use your Costco Visa you get a 4% rebate.Does everyone pay with a card ?
Around here, some do, some don't. Usually those that charge more for credit card are the already discount stations anyways. I've kept my VISA card through AAA because I get a gas rebate.Does everyone pay with a card ?
28 gallon tank?Now i have a ram eco-diesel with the 28 gallon tank, it is suppose to get close to 700 miles per tank
I still carry the 3 jugs full of diesel.
The ecodiesel has the same fuel tank options as trucks with the Hemi or Pentastar engines. Those options are 23, 26, and 33 gallons. But availability is somewhat limited by model or option choices. For example, the 23 gallon tank is not available on a Limited.mikeru
am i incorrect, is 28 gallon not the only size that you can get with the eco-diesel engine ?
Stavinksi
When i had that setup, the Law stated that the auxiliary tank could not be connected directly to the vehicles tank.
In other words, you could not have a Switch or valve in the cab that would allow the auxiliary tank to drain or pump into the vehicles tank.
It is perfectly legal the have a Transfer Fuel Tank.
My particular Transfer Tank had a pump & fuel nozzle, that pumped something like 5 gallons a minute.
The pump is Blue & you can plainly see the fuel nozzle.
