shadowhawk
- Oct 30, 2017
- 3,620
- 2,813
- Location
- Southeast WI
- Black metallic 2016 Sport- born 05/2016
- hemi 5.7 with I2 tune
that is right on the money ! lol ... I honestly thought they would be tucked in ...
-24 offset on the wheels
and I did have rubbing at first on the front bumper. We trimmed that, and I still have rubbing at full lock at the rear of the liner.
But you only have the 1.5 body lift with the 2.8 5100s, for some reason I thought he had a 6" lift ... but that is still crazy, my buddies truck has a 4" lift with no rubbing and you should have just a bit over 4"s while he is only at 4" with no body lift or bills cranked up at all ...
Yeah mine has a 6" lift, so should be good?
I'm not sure why, but it's only on full lock. I don't know why I rub when technically, I might have more lift than he does. What's his wheel well height?
so I wonder if it's because of your approach angle. I'm straight on level and you seem to have a fairly sharp angle. No one else has been able to get in under the 7' clearance with more than a 4" lift.
I have a 4x4 with a 6” lift and I’m sitting a hair under 45” front and back (and that’s still only on 35s). I brush the weatherstripping on the top edge of garage opening currently if I try to pull in.Possibly ... and keep in mind, the fender flares are taking away about another half inch due to the thickness of the flares, if I remember correctly the actual measurements were 44 front and 46 1/2 rear without the flares ....
They are not flush with the bottom of the wheel wells at all, at least not at the outside point of the flares ...
When I swap to 37s the truck will be higher and won’t be fitting in the garage anymore. My garage is very level with the driveway itself if that matters.
I don't have measurements on my fenders but I can't fit into a 7' garage on 37's because the damn shark fin antenna will be destroyed. Ironically I could fit when I had 35's.
