I currently have a 2017 Ram 1500 limited with the 4 corner air suspension. Every now and then I want to raise the truck up to the offroad 1 or setting but I guess due to manufacturer settings the truck will automatically lower itself after getting up too 35 mph. Is there anyway I can change this setting?
I have 5th Gen 2021 Rebel. So exit/enter, aero, normal, off-road only options. It also lowers around 35 KM
I find it annoying, when it lowers and then I have raise it. I off-road often with my truck.
There is no direct way to do it in AlfaOBD. I'm sure it's possible, but not enough people want/request that feature.
So option would be as
@Bandit517 mentioned above. There is section for Air Suspension. And you can adjust levels. I haven't done it on my Truck yet. My plan was to take "normal" mode and adjust the settings to same as "Off-Road" since I never use Normal. Only aero for driving highway and Off-Road when Off-Roading.
I would mention to be careful. If you lift the truck too high and something happens at high speed, you could kill/hurt yourself or some one else. At the lower speed, it's more controllable.
