4wd front axle release, (how does it function?)
DeepVee
Cummins6.7
For decades I've been driving full size Fords with manual 4wd. "Old school" with transfer shifter and manual lockout hubs. My new 2016 3500 has a front axle that is foreign to me. It appears the front axle releases in 2wd by means of the mechanism on the passenger side of the differential.
Does anyone have a simple explanation, or know where I might look online to learn more about it?
Thanks a lot.
keithert
It may not release. Many 4x4 always have the front axle engaged and only supply power when the transfer case is in 4x4 mode.
Sent from my LGLS992 using Tapatalk
Danno
Mid Atlantic
2016 Power Wagon
This is an old illustration but same principle.
opie
There is an aftermarket manual hub kit for the 2500 as well. Don't know any details just stumbled onto it looking for something else.
Sent from my SAMSUNG-SM-G920A using Tapatalk
D
DeepVee
Cummins6.7
Thanks all. Perhaps this the front disconnect you're referring. Enables 2wd low range. With my Fords, I would often use 2-low without locking the front hubs. Very nice and convenient for backing trailer up a steeper grade, takes a lot of strain off the transmission.
https://dieselperformance.com/shop/...0-2009-2016-2500-2014-2016-3500-2013-2016-586
BossHogg
Oakland Township, Michigan
6.7L Cummins
Thanks a lot.
Here is a discussion that directly discusses the uniqueness of RAM's front axle disconnect;
2013 4x4 front axle disconnect - 2500too, or just 3500? - Dodge Cummins Diesel Forum
loveracing1988
Clarkston, MI
Any kit that would fit a 2015 fits from 2014 to 2017 at least.
Aside from getting the free spin conversion to enable the use of a 2low there is no other point to it. The disconnect is already there so you aren't gaining any fuel economy like the 2013 and older trucks.
No, this.
http://www.xtremediesel.com/Yukon-Y...k1xV6h8wmlpubvfN13jRkHDIq35438X2NEaAt8z8P8HAQ
I did see kits that go up to 2015 if my memory serves me.
Sent from my Nexus 6 using Tapatalk
BossHogg
6.7L Cummins
I have not yet ordered this kit but I think I am. Benefit is need based, to get it just to get it you are right, but if you are like me you will enjoy it.
When I am maneuvering in a campground backing the 15K pound fiver into a campsite I always use four wheel low. Being in low makes maneuvering so much easier but the unwanted side effect is binding, this kit removes the binding.
keithert
How does the front axle disconnect on a 2016 1500?
