5.7 eng shake at idle
ike43
kingston on canada
just bought a 2006 15004x4 wondering if intermittant eng shake very slight but can feel it in truck is normal for the hemi or could it be a miss? changed plugs and air filter and ran 1 bottle of inj clean through already but still there , any suggestions?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Has it thrown any codes and what does the tac do during the shake? Do any lights come on the dash? Mileage and possible dirty TB. Kinda hard to say without more info. How does the truck also do around town?
ike43
ike43
kingston on canada
no codes no lights, and tach dosent move that i can see but i know its a hemi but it does seem to be excessive on fuel no smoke either maybe the tb is dirty ? its has 60000 km or approx 45000 miles on it
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
What do you consider excessive on fuel? Normal ball park is around 15 MPG on these things. I really doubt the first owner changed the plugs but I could be wrong. They can be a pain to change without the right tools but can still be done. Normal change is 30k or 35k cant remember at the sec but they can go longer if good fuel is ran all the time.
ike43
ike43
kingston on canada
i havent calculated the mpg let but i estimate around 10-12 mpg ,i changed the plugs myself not too bad but i have the tools the old plugs gaps were .050-.055, but new plugs didnt make a diff, i havent looked close at the tb yet do they get that dirty easy
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
The can but shouldnt be causing alot of your issues, if you do clean it use brake cleaner only and be mindful not to spray alot near the ectertonics. That milage seems low wonder if anything funky is goin on with the injectors.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
The can but shouldnt be causing alot of your issues, if you do clean it use brake cleaner only and be mindful not to spray alot near the electronics. That milage seems low wonder if anything funky is goin on with the injectors.
sorry had to edit and did it the wrong way
ike43
ike43
kingston on canada
on the hemi when cleaning the tb should use tb cleaner and spray with eng running or can you clean it with brake clean eng off then start after?
AWE Daniel
Banned
Get some non-chlorinated brake cleaner, works good and wont damage the finish inside the TB. Yes they do get dirty very easy. Check out what mine looked like.
After its clean make sure you calibrate the TPS, turn the key to run, let all the lights go out (the engine light will stay on). Press the accelerator all the way to the floor, let it up and turn the key back off.
ramhunter9
P-Star Jeep Wrangler
make sure all plugs are gaped the same ... i think this is your problem .. i had a buddy with the same problem .. 3 plugs were not gaped correctly .
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
The backside of the blade is what gets so dirty like in the pic posted above. Claning with TB cleaner is a 50/50 shot of jacking yours up. The TB cleaner messes up the electronics on these things.
ike43
ike43
kingston on canada
alright im going to try cleaning the tb this weekend , do i need to replace any oring or gasket when removing tb to clean?, also what do people think of adding a throttle body spacer?
AWE Daniel
Banned
No gasket, spacers are opinionated, some people like em, most dont
ramhunter9
TB spacers are a big paper weight ... junk dont do it waste of money
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Remove the TB when you clean it.
Rumblebee#2331
Vernon,Ct
throttle position sensor can also cause this problem had it on a few vehicles, lowered mpg shuddering and surgeing or stalling at a stop and or highway, thats where I would go if it was my truck seen it happen a few times
ike43
ike43
kingston on canada
well i removed tb and cleaned, was a little dirty but not bad all plugs new and gapped at .045 champ copper, still has a very slight shudder at idle when cold but not noticiable after its hot but does happen occasionaly put another bottle of inj clean in it will see if it works
ramhunter9
do you have a exhaust ???
mt truck does this at idle because of the exhaust rumbling ... could it be so easy ???
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
If you get a chance post a vid of what its doing.
Orca
