_Steve
- Joined
- Jul 17, 2022
- Posts
- 18
- Reaction score
- 12
- Location
- Western Washington
- Ram Year
- 2022
- Engine
- 6.7L I6
Here is the result of selecting 3 levels for the wheel heat ...Mine is set to not programmed, but that setting has nothing to do with changing the steering wheel heat levels.
Seats A:Heated Wheel Levels: High / Med / Low / Off
The result: With each subsequent push of the wheel heat button there are two visual and one tactical indication of the setting …
- The button: Unlike the seat heat which has three bars indicating the set level, the wheel heat button has only one bar. The AlphOBDII change resulted in the button indicating: On / On / On / Off
- The touchscreen display: Unlike the heated seats icon which shows three bars indicating the set level, the heated wheel icon shows only one bar. AlphOBDII change resulted in the icon indicating: On / On / On / Off
- The physical wheel temperature: After the AlphOBDII change, subsequent presses of the button resulted in the wheel temperature being: High / Off / Off / Off
Any more ideas?
Thanks
