big_rammy
- Sep 24, 2017
- 4
- 0
- 2017
- hemi 5.7
First post on this forum!!! I been reading and learning a lot so far but I do need some clarification on some things before pull the trigger.
2017 big horn
1500
4x4
3.21
CC
Caven exhaust
Pedal commander
8 speed trans
Planning on running a BDS 6" with 35s on stock 20s with spacers for now....
(37s would be choice)
Tires will probably be Ko2's or something similar that's not too heavy. All with the 3.21 gears. ****** deals...
That being said, regearing would be next on the to do list.... What I've gathered so far is that the 2012+ rams supposedly have the ring welded on the carrier in the front diff... So the only way to regear would be to swap out the front diff with a 3.92 diff or get a used 2010 front diff and make a Frankenstein build. Correct?
By using a 2010 diff I assume it's not going to be plug and play. More like pay to play [emoji2365] Besides the new front n rear gears, what else would I be looking at to accomplish this? New motor mounts? Drive shaft? Etc...
The truck is a daily driver with occasional light offroading to get to the fishing spot.
Thanks
2017 big horn
1500
4x4
3.21
CC
Caven exhaust
Pedal commander
8 speed trans
Thanks
