Hemi395
- Joined
- Mar 18, 2013
- Posts
- 8,989
- Reaction score
- 15,672
- Location
- Cape Cod MA
- Ram Year
- 2013
- Engine
- 5.7 Hemi
Not only that, the MPG improvements this gives you is miniscule. I doubt it would save you $5 in fuel over the life of the truck. I'll gladly buy another 2 gallons of gas and have my transmission last longer.The CAFE tech will lower the life span of your trucks most expensive pieces. Spend the money, fix what you can.
Agreed! There's no way the same tune lasted 70K on the stock transmission with no issues if it was a bad tune. They put the Sonnax Smarttech overdrive drum in, a shift kit and I can't remember if anything else but it sure as hell wasn't the tuning. Jay's awesome and I'm 100% going to get his tune on my next Mopar. Like I said, if they weren't fixing it for free I would have gone elsewhere the second time around. Jay suggested if it goes again, just finding a low mileage stock transmission and running it until I trade in.There's no way any good tuning on a 5.7 Hemi can cause 5th and 6th to burn up like that. On 6.7 Cummins yes because a tune can add up to 300hp. I've had custom tuning for well over 30k now and towed my 4k lb camper across the country and back. No issues with my 65RFE.
They either put in a bad solenoid pack or didn't put that clutch pack in properly. Whatever happened it's on them not the tuning. You legitimately would have had to do something like 15 WOT downshifts at highway speeds to burn a new 5th/6th clutch up.
Sucks man hope they or someone else takes care of it for you, keep us updated.
Little bump on a great thread here. Getting ready to tackle this over the weekend.
Truck has nearly 90k km's and this'll be 2nd trans service (first one at 60k).
I have the MH pan and the highly regarded C+ to go back in (******* that stuff is expensive especially for us Canucks!). Also picked up a RP spin on filter from the synthetic filter thread, has anyone tried this one yet in their trans? Still have to sand the paint off before installing. My DNJ billet channel plate, valve body/solenoid pack, and thread adapter showed up yesterday so chomping at the bit here!
I know I'll have to do a quicklearn afterwards, has anyone done this with the AlfaOBD by chance? The option is there, and Alexey told me he has reports from Ram guys that have been successful so I guess we shall see.
PLEASE let us all know how it goes.
There’s a guy on another form that has been running Fram filters in his transmission for quite some time now. I can’t see how the royal purple would be any different.
What’s your plan for the filter getting threaded into the transmission. Did you buy the steel adapter or are you going to try and take the plastic one out of an OEM filter and put it in the royal purple?
What codes have you been getting?I will indeed.
I'm hoping this will help with the couple of nuisance codes I've been getting for a while too (with no drive ability issues, knock on wood). Been actually paying attention to my temps lately and I've seen it climb to 170. I don't tow at all either.
