Just got the bypass kit caulk thanks!!!
Is there a how-to on doing this?
do I remove that brass plug to get to it? Thanks!
edit: sorry I go by M2k on 5th Gen forum
The improvement is lower trans temp which is also beneficial for line pressure and longer transmission life. Possibly even better efficiency in the torque converter. You won’t have any power increase because you didn’t change anything related to making power.Yeah I didn’t put the long spring in. When I tried to take it off the original tstat the whole thing fell apart.
I’m stumped no real improvement for me so far.
What are your temps? Should definitely be lower unless you have the grill shutters still. Those will keep the temps higher. My temps are 132° when fully warmed up cruising.Thanks power was not my goal, cooler temps are. Though empty with 3.92 and quad cab it runs like a ***** ape already lol. Ask the newer three series that thought I was racing him during my wot runs lol. He couldn’t hang
I’m just not seeing a drastic change in temps if any at all right now with this modified tstat in my 5th Gen 8hp75...
145° beating on it’s pretty good. I hit 152° after 4 back to back 1/4 mile runs. Lol.I have modded my AGS, only have middle and bottom slats no CEL.
I really beat on it and drove it like I stole it. My high temp posted is after that beating. The lower temp one was me being easy on it to warm up, was hoping it would stay there like you guys
I installed it just like caulks pics. Now I want to go to the 180 tstat. Or Maybe the 5th gens are a pita compared to the 4th gens
Today was the first day i've really put any miles on mine on the highway for any length of time,and on average my tranny was running between 115 and 120.That's with the heater assembly completed deleted / deeper PPE tranny pan and my crossover under the tranny pan is double wrapped with header wrap / 160 thermostat and most of the shutters deleted,just top and bottom rows of the shutters left in place.Outdoor temp was 71F with the cruise set between 75 and 85 mph.I sure notice the truck holds 8th gear alot better,hills where it used to downshift to 7th it stays in 8th with the cooler temps.I even did a couple nitrous pulls to about 110 mph for ***** and giggles and the tranny only went to 122F,and as soon as i backed out of it,dropped back down 115 in less then a mile.
