bradluster73
I've done a swap from one truck to another same year and all just one was 1500 and the new truck is 2500. Well after I started it would run good for 5 minutes then just idle and popping and cut out and die but will restart after 5 minutes. I've changed the crank and cam sensor map and tps cad has been knocked out fuel pump is new. What else could there be?? The only thing left is ignition switch and wiring going up the column
Sent from my SM-A205U using Tapatalk
