RangerRay
So my 99 Ram 1500 with the 3.9 is having some idle issues. When you first start it you have to give it a little gas or it'll die. After it runs for a bit I can take my foot off the gas it'll run just fine. I've replaced the idle air control valve, tps, and went ahead and replaced the throttle body gasket and no help. Now before I replaced the iacv it idled way too high. After I replaced that it now idles too low. Its also throwing a check engine code P0505 which is idle air control system. Any suggestions on what it could be would be greatly appreciated.
