A trailer with no brakes?
Discussion in 'Towing & Hauling' started by Mpeach1976, Dec 21, 2015.
  1. Mpeach1976
    Mpeach1976 Junior Member
    10
    Nov 6, 2015
    Ram Year:
    1995
    Engine:
    Cummins diesel
    I'm going to be using my '95 Dodge Cummins 3500 dually to haul a 1967 ford f100 on a Uhaul car transport trailer. I've reserved the trailer and also found out that the trailers Uhaul rent don't have electric brakes. Is that safe? The Ford being towed weighs about 3500 pounds. It'll be a cinch for my truck to haul, but I'm concerned about downhills and stopping power on the trailer. Has anyone towed a load like this on a Uhaul trailer with any problems?
  2. dodge dude94
    dodge dude94 Senior Member
    23
    27,476
    6,271
    Sep 5, 2013
    East Texas
    Ram Year:
    1998 Ram 1500
    Engine:
    5.9 Magnum
    You have a 1 ton....it'll be just fine. You may feel it push a little bit, but you'll still stop fine.
  3. Rlaf75
    Rlaf75 Senior Member
    333
    70
    Nov 13, 2015
    East Hartford CT
    Ram Year:
    Engine:
    You'll be fine since your ram is big enough.I used to be a tow truck driver. My wrecker was a 92 f350 7.3 diesel 4x2. I've pulled several vehicle the same size and larger without any type of braking system without any problems. Just give yourself some extra distance and time and you should be fine.
  4. tsc
    tsc Senior Member
    124
    34
    Jul 27, 2015
    Ram Year:
    Engine:
    Some Uhauls have hydraulic brakes installed.
    I'm pretty certain if you're going to be using one of their car haulers. It will have hydraulic brakes, since I can't see them renting out something that wasn't "legal". Most states and province's require trailer brakes over a certain weight (anywhere from 2K to 3500K+).
    Uhaul tends to use hydraulic brakes oppose to electric, since it covers their backside. If they came with electric, they would have to ensure that the renter had an electric brake controller in the vehicle. This way, with the hydraulic, it's attached to the trailer and it's one less thing they have to worry about.
    dodge dude94 and Merc225hp like this.
  5. OutLore
    OutLore Senior Member
    159
    39
    Jan 12, 2013
    Raleigh, NC
    Ram Year:
    Engine:
    I've towed a 1950 Studebaker pickup (probably around 3500#) on a U-Haul car hauler twice - once with a U-Haul truck from TX to NC and then from Raleigh to Louisburg (40 miles) with my Ram (1500) - they do have hydro brakes, but both times I didn't feel there wasn't enough braking available.
  6. RonJon '06
    RonJon '06 Senior Member
    3,304
    1,047
    Jan 2, 2014
    Southern Minnesota
    Ram Year:
    2006, 1985
    Engine:
    5.7, 360
    I've towed a few 1/2 ton pick ups with my '06 2500 on a trailer that has electric brakes...that don't work...and its been fine. Leave yourself some extra room like Rlaf75 suggests and if the Uhaul has hydraulic brakes even better.
  7. CVX20
    CVX20 Senior Member
    62
    237
    72
    Sep 13, 2015
    Ont,Ca.
    Ram Year:
    Engine:
    Knowing how U-HAUL operates,they've probably never serviced the brakes.
  8. bcbouy
    bcbouy Senior Member
    1,084
    399
    Nov 12, 2014
    pitt meadows
    Ram Year:
    2012 ram 2500
    Engine:
    hemi
    if i were you i wouldn't tow a truck on a trailer without some kind of braking system.if for any reason the trailer comes away from the truck its going to kill someone.don't think it can't happen to you.
  9. Rustycowl69
    Rustycowl69 Senior Member
    858
    159
    Oct 24, 2015
    Ram Year:
    2001 ram 3500
    Engine:
    V10
    At least make sure you have enough tongue weight.I was towing my race car on a trailer with no brakes. I thought I had positioned the car on the hauler with enough tongue weight, I was wrong. It was about 3 or 4 inches shallow. I had just gotten on the freeway, there was a long incline, then when I reached the crest of the hill and started down the other side, I touched the brakes and the trailer started wagging. I could see the trailer on my left side with my peripheral vision, when I was facing forward! Fortunately, the rush hour traffic parted, and slowed waiting for me to crash, but I was able to wrestle it to a stop. Had I had trailer brakes, It probably wouldn't have happened, or I could have settled it with the brake controller.
Share This Page
