Hello fellas . Camper shell will weight around 600-700 lbs with simple plywood beds made in the bed . I also pull a TT or utility trailer with SXS . Each has a tongue weight of 350 ish lbs . I do use a WDH with the TT .
I figure the truck will settle some with the shell on it and honestly like a little rear rake . I am also considering raising the front a hair ,1 inch so the front air foil under the bumper don't rub the roads at deer camp .
This is my daily driver so a good ride is needed . I have stock tires and wont be getting taller tires but will increase the load rating .
This is my first truck with coils spring rear suspension . I like it just fine . I know that I will need to do something for the rear when I get the Belair type camper shell installed .
I do no 4 wheeling or anything like that I just want the truck set up correctly for what I use it for .
Any help would be great .
Looks like the TTC1211"s are maybe a good one ? I want to keep a small rake with the camper on and be around level when hooked to a trailer .
Thanks .
Thanks .
