Adding homelink
Azmp1
Hi All,
I cant seem to get the homelink working, that i've added as part of the overhead console install. Have the power/ground and linbus wires connected, but nothing is happening. The question i have is, for the trucks that never had homeling (no harness either), do they need to get enabled via alfaOBD first? What throws me off, are two things, first, all the videos i've seen, people have the 7" screen cluster, where there would be a homelink setup options, but i have the basic cluster and there is no menu there for homelink and two, i dont even get backlight come on the homelink when its connected. Why would that be? I would think just the having power to it, should have, at least backlight work on the buttons? Or maybe i just have a broken module... Thank you in advance.
SitKneelBend
St. Louis
3.6 Pentastar
Hi All,
Possibly broken. Plus it must be 2013+ for trucks after 2013. The 2009-2012 one will work but will not show messages in the cluster for learning/transmitting. There aren't any homelink menus in the cluster or radio, just notifications.
Azmp1
Azmp1
Figured it out. Looks like i have the pre 2013 moduie.. damn it. Should have checked here before buying, so just ordered a correct one. Still one more question, will it needs to programmed, through AlfaOBD, since my car didnt have the console and harness. Thank you for your help again!!
SitKneelBend
St. Louis
3.6 Pentastar
That I'm not sure. I had a console without homlink (compass only) and it was plug and play. I know there are compass module settings you can change in AlfaOBD (like installed orientation to get a correct compass heading) so my answer is "maybe"...
Azmp1
Azmp1
ok.. im struggling here hahah. Got the correct module (from a 2104 truck, same as mine). Have it connected, backlight is now on, on the buttons, so power is correct and im sure im tapping the right wire for lin bus, but nothing comes up on the screen when i press buttons... HELP!
edit: I didn’t have compass module either, so that makes me think I may need to enabled it. I just got Alfaobd and MX+ and did a EVIC cluster milage sync, so no I have an EVIC cluster and still no homelink messages. what I don’t know is where to go to enable compass module. If anyone can point me to it I’d really appreciate it. Thanks!
SitKneelBend
St. Louis
3.6 Pentastar
AlfaOBD settings to change:
Car Config change ->
Lin and Misc-Electronic Overhead Module(EOM) ->
value,YES
Azmp1
Azmp1
value,YES
Found it, and that’s exactly what it was! Once enabled I’m now getting homelink messages and was able to program it successfully!
So for reference for others if no compass module originally, meaning must do this in order to have homelink enabled.
Thank you again man!
SitKneelBend
St. Louis
3.6 Pentastar
Anytime!
Azmp1
Azmp1
@SitKneelBend another question. Since i now have a working compass module, how do i get the compass heading on to the EVIC screen, is that another AlfaOBD adaptation?
SitKneelBend
St. Louis
3.6 Pentastar
Here's what @Jimmy07 verified for me as a known good configuration when I was troubleshooting a compass heading issue.
VehConfig 3 display compass heading present- yes
LIN and misc compass mounting orientation- upside down
LIN and misc EOM present- yes
LIN and misc compass mounting angle- 0 degrees
CustSetMenu 1 compass calibration CSM- yes
Azmp1
Azmp1
OK thanks, i will try!
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
Right below "Calibration CSM" , there is another display item you may want to add, too: "Compass Variance CSM Present: Yes".
If that is way off, it could be reason for flakey operation.
Azmp1
Azmp1
So, i have it all set, heading on EVIC is there now as well, but the compass doesnt seem to be functioning correctly. I drove around a bit and just switches between N and NE and not correctly either. I double checked all the setting through Alfa, all look to be set correctly. Did i miss something else, maybe around calibration? Thanks!
SitKneelBend
St. Louis
3.6 Pentastar
It may require calibration. I was told a long time ago the process is as follows:
"Find a place to drive around in tight circles until the heading displays correctly (should be 3 to 5 times)."
I've also been told that this needs to be done with the drivers door open and left-hand turns only.
Azmp1
Azmp1
It actually makes sense (aside from the open door haha). I will try, thanks!
Azmp1
Azmp1
@SitKneelBend It worked, as it just needed calibration, as you stated. The only caveat, is you have to put the compass in the calibration mode, via compass settings on uconnect, so for me, since i already had the aftermarket unit in, i had to swap the uniconnect back in, to be able to that, as it cannot be done via cluster settings. So hopefully, this will be note for anyone with aftermarket units. I was going to throw my uconnect on ebay, but will just keep it, if i ever have the need to recalibrate. Also, another note, the compass offset must match the region you're (can be looked up on the web) and thats another setting that can only be accessed through uconnect.
SitKneelBend
St. Louis
3.6 Pentastar
Interesting, I've never seen that setting. What year is your truck again?
Azmp1
Azmp1
It’s 2014. The compass settings are under the settings menu on unconnect. I’d take a picture, but I’ve swapped the android unit back already
