Air Lift air helper springs
destroyaYO
5.7L V8 Hemi
I am running airlift load lifter 5000 on my 2004 ram 1500 with a 6" lift (leveled so 4" in the rear). So I have to use a 4" spacer. The one sent to me are tapered but they make a non taper too.
Which way should the taper taper?
Or should I even be tapering.
I do towing often so the air bags are very helpful.
Backroad Joe
2006 4x4 2500
HEMI 5.7
Driveshaft angle. You want to maintain the existing angle of the driveshaft in relation to the differential. As you lift the suspension the angle changes. The tapered blocks rotate the axle to regain the original angle, or close to it.
Orca
