Backup Cam Dim at Night
Brian_Ram
Greetings,
When backing up at night in a dimly area I cant really make out anything other than the guidance lines. Day time and areas with street lamps are fine. Any suggestions?
Thanks
Brian
Am3gross
VIRGINIA
HEMI 6.4
are your reverse lights working? take a picture if possible so we can see.
R.L.K.
Bristol , Tn.
Mine is pretty good at night ? What display do you have ? Mirror , RA2 5.0 Radio or RA4 8.4 Radio?
B
Brian_Ram
I have the 8.4. The display picture quality is fine during the day or at night with sufficient overhead lighting like street lamps. But when I visit a couple friends that live in a rural area with no street lamps the display is pretty dark.
B
Brian_Ram
Yes, reverse lights are working. I just swapped stock out for Anzo's and I havent been out in a dark area yet. I'll see if that makes a difference and if not I'll get some pics.
sbarron
Wasilla, Alaska
the amount of light doesn't sound like the issue. your camera should adjust the aperture inflow light conditions, (at loss irresolution)
R.L.K.
Bristol , Tn.
In a completely dark environment with just my stock back up lights I can see the surroundings at least as far as the active gridlines.
Your camera should have a much better night vision .
SitKneelBend
St. Louis
3.6 Pentastar
LED reverse lights help, but these cameras aren't great in low light.
