Bad white smoke at start up
Mcsheffery
Montana
05 dodge
5.9 cummins
211,000 miles I'm getting pretty bad smoke at start up. Lasts about 5 mins pretty rough runninh until warmed up then seems to run great. Head gasket? If so how long do nbn I have generally before i NEED to get that fixed. Iv replaced front timing case gasket, rear main, trans cooler, radiator, flex plate all in the last 5 months about sick of working on this thing. Edge chip, cold air intake 4in turbo back exhaust
Sent from my SM-G965U using Tapatalk
mtnrider
Georgia
Sounds like leaking/sticking injectors. Unfortunately running a tuner with increased rail pressure isn't doing your injectors any favors
Ramnewbie
White smoke from a diesel usually means injectors. I'd try a good diesel fuel additive first before tearing into it. I know alot of guys run Lucas fuel treatment, but I'm sure there's more and better ones on the market. Hopefully a longtime diesel guy will chime in with a particular product.
Sent from my XT1650 using Tapatalk
mtnrider
Georgia
Trying running some Power Service Diesel Kleen and see if that helps. I used to use it in my old 5.9. It might help?
Other then that you need to diagnose the problem before you start throwing parts at it. Get a leak down test done on the injectors so you can see if that is the problem (that's my bet).
ramcumminssix
billings
Cummins 6.7
try sticktion eliminator from hotshot secrets. i have seen it bring injectors back from the dead and save people thousands
Diller
Nashville TN
6.7 HO Cummins
Typically no fuel additives are going to help if the injectors are not working properly. 200-250K miles is where most people get before new injectors. The issue could cause etching of the cylinder walls if not corrected. Basically the spray pattern turns into a waterjet that cuts if left long enough. It can also damage pistons as well. White smoke is something that you want to have addressed sooner rather than later. Its not a hard job at all, just a little pricey for the hardware.
