ball joints
bigtigga84
dela....where?
are the upper ball joints serviceable on these things or does the whole UCA have to be changed to one that is. I heave heard yes and no. some sites you can find the uppers sold out of the arm, but don't say if the factory arms can be used. clarification would be most appreciated. :)
02ram
around
4.7L
you have to change to whole uca
Deviate
St. Augustine, FL
2005 4x2
Yup, the upper control arm and ball joint are one piece. You could replace them with new ones that are serviceable and have grease zerk fittings.
txbass06
NE Texas
5.9 Magnum
IIRC, Moog makes a replacement Control Arm that has changeable ball joints
ramhunter9
P-Star Jeep Wrangler
Moog are junk , get a Carli set
Trupiano
Registered User
6.7L CTD
I had Moog's on my 90' CRX worked perfectly. Also have them on my ram now. I love that they have the grease fittings, so I can regrease them and they'll hopefully last longer. Never had a problem with mine.
Trupiano
Registered User
6.7L CTD
$450? For just the ball joint itself??????? **** that! I bought my Moog upper control arms for like $50 bucks each, and they work just fine on my 4x4!
The Assassin
B-more careful, Murderland
I need to replace mine, prior to installing my suspension lift, as well as the tie rods. We should talk to Duane...see if he can get a gb.
The Assassin
They are actually for the 1500 Mega cab, which is the same suspension as the HD's. Damnit! I'd buy a set...idk about the price, I just need a bullet proof suspension!
weedahoe
Banned
South GA
cammed and custom tuned 5.7
No way i would pay that much for BJ unless I was sponsored and didnt have to pay it myself. Go buy your BJs from Ebay or RockAuto IMO
RubberFrog
Dan, don't replace it prior to the lift. That makes no sense. replace it while you're doing the lift and save some labor cost.
ramhunter9
Upper and lower Ball Joints are the only thing well main thing keeping a SFA truck from loosing a wheel . You dam right 450 is a good price for safety and piece of mind .
JustinRam1500
