battery negative cable locations on engine /frame
Thomas Nograsek
Charleston, south carolina
2004 Ram 5.7 hemi Larmie - replaced 5.7 hemi with exact same year & truck engine. All is going well on the install UNTIL THIS issue came up. While all electrical sensor connectors were tagged with labels the negative battery cables were not. Where in the hell do the cable ends bolt to? I mean the location. I'm sure one end goes to the engine and the other end goes to the frame but WHERE. i know there are three leads from the battery terminal. One to the body (yep got that) but the other two - ????
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
Service manual says G100, G101, and G102 are the three locations. G100 and G101 are left front engine, and G102 is left front chassis.
Sorry, I don't have a picture for you.
Thomas Nograsek
Thomas Nograsek
Thanks. The left front chassis is a easy one to find - right near the battery. The ones on the engine are a bit harder in this respect - there is one location near the front by the oil dipstick, the other location I can't find plus the cable leads for these locations - one cable is of heavier gage than the other, So which one goes where? I'm thinking the lighter gage goes to the location near the oil dipstick the heavier gage goes to a locaton nearer the stater. We'll see!
WhiteExpress
Midland, TX
I just happen to have an '04 sitting in the garage myself.
The 3 wires go:
One to the fender immediately to the right of the battery.
One to the outside of the driver's frame rail (almost directly straight down)
One to the block right behind the PS pump (See attached picture)
Thomas Nograsek
Thomas Nograsek
Thanks. That is exactly where I found the locations. The one to the frame had me baffaled until I realized it goes to the outside of the frame! Thanks again
Racc_506
New Brunswick canada
I’m having trouble finding the one on the frame i know of the one on the block behind the PS pump.
Racc_506
Thanks. The left front chassis is an easy one to find - right near the battery. The ones on the engine are a bit harder in this respect - there is one location near the front by the oil dipstick, the other location I can't find plus the cable leads for these locations - one cable is of heavier gage than the other, So which one goes where? I'm thinking the lighter gage goes to the location near the oil dipstick the heavier gage goes to a locaton nearer the stater. We'll see!
Mine was disconnected where does the one on the frame go I don’t see any spots for it.
JustinRam1500
