Battery replaced, radio not working
precisionmike
Hello,
I have a 2014 Ram 1500 5.7 Hemi. I just had to replace the battery. Now I have an issue with the radio. The BU camera works, but when I am in drive I get either the ram logo or a blue screen. I did check all fuses, including the "hidden" in line radio fues. Any ideas?
TIA, Mike
ExpressRules
Southern New Jersey
2014 Express Crew Cab & 2019 Big Horn Crew Cab
Did you try disconnecting the battery and then reconnect to see if the reset helps?
adurm
FL
2015 RCSB
I would suspect you would have no screen function if it were a fuse. Time for an upgrade!
RamCares
n/a
n/a
Hello,
TIA, Mike
Hi Mike
You can try performing a hard reset on your Uconnect system by following these steps: Settings -> System Information -> Reset to Factory Default. Please be advised this will delete any saved information such as radio presets, Bluetooth pairings, etc. but it could help resolve your concerns. If this doesn't help please send us a PM with your VIN so we can investigate further!
Andrea
Ram Social Care Specialist
P
precisionmike
Hi Mike
Andrea
Thanks very much! I will try this tonight and report back, I appreciate it!
P
precisionmike
Hi Mike
Andrea
This might work if my radio was responsive. I only get the Ram logo on screen, regardless of what buttons I press. Please advise, thanks again.
Rado
US NAVY VETERAN
Maine
Pentastar 3.6 V6
Mike you may get a response faster from RAM care if you PM then direct! Good luck with your issue and please update us when you find the issue!
RamCares
n/a
n/a
Hi precisionmike,
Thank you for clarifying, we would recommend visiting your local dealership for further diagnosis. If you decide to make an appointment please send us a PM with your VIN so I can offer further assistance!
Andrea
