TRXHemi
- Joined
- Jun 3, 2013
- Posts
- 1,043
- Reaction score
- 349
- Location
- Sugar Land, TX
- Ram Year
- 2014
- Engine
- Hemi 5.7
I purchased a 20" LED light bar for behind the grill. The only issue I had was the active shutter system. So I removed it. I did remove the actuator from the assembly, but I kept it connected, as it popped a CEL.
EDIT: I pulled the battery cable, and it reset ok, but the CEL has come on again.... the active shutter motor is connected still, so not sure what the issue is. ANY IDEAS?
I will post some night output pics later today.
You can see here how it is mounted and the active shutter mechanism mounted out of the way:
Testing to make sure it works before putting it back together!
And installed:
Night output LED only:
Night output LED and HID heads:
And finally, some clean shots of the truck!
And installed:
