deerreeper
Nice boat and set up. You definitely have surge brakes. The none painted part of your trailer that hooks to your ball slides inside of the tongue on the trailer and applies pressure to a master cylinder when you stop. Works the same way as the brakes on your pickup. The harder you press the peddle the more braking power. Being a new trailer you shouldn't have any problems with them but stranger things have happened. I would say it's exactly as the one member mentioned, that your trailer is bouncing behind you with no weight on it and it just feels like the brakes are on. Since this is all new to you, you are probably a little nervous and hyper sensitive to every little thing you feel or hear. A couple of things you can do for your own piece of mind is to pull the trailer as you normally would, then raise the trailer up off of the ball. Then jack up each tire like your going to change it and spin it. There shouldn't be any brakes applied and should spin freely. If you have only a short trip back and forth to where you launch your boat. Go for a little longer longer drive. Get it up to highway speed for a little bit, keeping an eye on your mirrors, then stop a check your brakes. Surge brakes are a pretty trouble free system as long as they are maintenance properly.4300lb Boat
1400lb - trailer weight
Full set up and trailer pics attached, thank you all so much for the help!
Sent from my Moto Z (2) using Tapatalk
