RamNooby
Anybody know a good place to get some bolt pattern fender flares and what's a good price on them? I'm also not sure if you buy them and paint em to match your truck or if you buy em that color. Help Please!!!
haha ok that makes sense. And if I have a some rust bubbles forming above that back wheel well, do you think I should grind and sand that away and put some rust converter on it so it doesn't spread before I put on the fender flares?
The ones along the top are simple ... put the bolt threw the pre drilled hole and tighten the nut .. they are just for show ..
BH4L was talking about the mounting holes .
If you look inside the wheel well you'll see a few bolts inside the lip of the fender the hold the wheel liner
